On the DNS server, the error message is displayed.
This error indicates that an alias (CNAME) is associated with another type of DNS record.
The DNS system allow you to set up an alias to a system using the CNAME record. An example of this is:
alias1 IN CNAME host1.domain1. |
The alias alias1 cannot appear in any other type of record. Only the actual name of the host may be used. So, if you wanted to use this host as a mail exhanger, the record:
alias1 IN MX 10 host2.domain1. |
Instead, you should use
host1 IN MX 10 host2.domain1. |
Also, it is possible to get this error without explicitly setting the left hand side of a record. The DNS system defaults the left hand side to the last given left hand side. So you might have the following in a named database file:
host1 IN A 123.124.125.126
IN HINFO Sun Solaris
