A user tried to change directory (for example with cd(1)) to a network partition on the system specified after /net/, but this host either does not exist or has not shared (exported) any filesystem.
To gain access to files on this system, try rlogin(1).
To export filesystems from the remote system, become superuser on that system and run the share(1M) command with the appropriate options. If that system is sharing filesystems for the first time, also run /etc/init.d/nfs.server start to begin NFS service.
