Cause
After installing Solaris 2.6 on a system, when users try to bring up their calendars either with CDE's calendar manager (/usr/dt/bin/dtcm) or OpenWindow's calendar (/usr/openwin/bin/cm), they see the dialog box:
Calendar :Informational - NFS mounted callog file Unsupported.
Your default startup Calendar file appears to be NFS mounted or
a symlink to the same. This is Not Supported.
Continue
The following error is displayed in the console window when the Continue button is clicked:
date time host rpc.cmsd[pid]: rpc.cmsd :
NFS mounted callog file Not Supported - user@host
The calendars would've worked under 2.5.1 or before however.
