Install OpenGL 1.0 and test the configuration by running /usr/openwin/demo/GL/ogl_install_check which results in following:
# ./ogl_install_check
Xlib: extension "GLX" missing on display "0.0".
can't find visual
First check that the installation has worked correctly by running the package check utility on the runtime package: # pkgchk SUNWglrt. This should result in an error message such as:
ERROR: /usr/openwin/server/etc/OWconfig file size <187> expected <5423> actual file cksum <14394> expected <27045> actual |
Assuming that is fine, look at the process owner for the Xsun process using:
# ps -aef | grep Xsun | grep -v grep nobody 20022 225 0 11:36:22 ? 0:34 /usr/openwin/bin/Xsun :0 -nobanner |
If you are are using CDE, ensure that the Xservers file has the form
:0 Local local_uid@console root /usr/openwin/bin/Xsun :0 -nobanner |
Another way of proving this is to run OpenWindows from the command line as root. It will ensure that the Xsun process is owned by root.
Another possibility is that the system is NOT a Creator 3D. You can only run openGL 1.0 on an Ultra with a Creator 3D graphics card. If you install this application on an Ultra with a Creator framebuffer and NOT a Creator 3D you'll see these same error messages.
