This means that xterm(1) has lost its connection to the X server. The "0.0" represents the display device, which is usually the console. This message can appear when a user is running xterm and the X server disappears or the client gets shut down. Data loss is possible if applications were killed before saving files.
Try to run the terminal emulator again in a few minutes after the system has rebooted and the window system is running.
