The steps for the client to establish a connection are shown in Example 3-5.
if ((sndcall = (struct t_call *) t_alloc(fd, T_CALL, T_ADDR))
== (struct t_call *) NULL) {
t_error("t_alloc failed");
exit(3);
* Because it assumes it knows the format of the provider's
* address, this program is transport-dependent
sndcall->addr.len = sizeof(int);
*(int *) sndcall->addr.buf = SRV_ADDR;
if (t_connect( fd, sndcall, (struct t_call *) NULL) == -1 ) {
t_error("t_connect failed for fd");
exit(4);
The t_connect() call connects to the server. The first argument of t_connect() identifies the client's endpoint, and the second argument points to a t_call structure that identifies the destination server. This structure has the following format:
struct t_call {
struct netbuf addr;
struct netbuf opt;
struct netbuf udata;
int sequence;
addr identifies the address of the server, opt specifies protocol-specific options to the connection, and udata identifies user data that can be sent with the connect request to the server. The sequence field has no meaning for t_connect(). In this example, only the server's address is passed.
t_alloc() allocates the t_call structure dynamically. The third argument of t_alloc() is T_ADDR, which specifies that the system needs to allocate a netbuf buffer. The server's address is then copied to buf, and len is set accordingly.
The third argument of t_connect() can be used to return information about the newly established connection, and can return any user data sent by the server in its response to the connect request. The third argument here is set to NULL by the client. The connection is established on successful return of t_connect(). If the server rejects the connect request, t_connect() sets t_errno to TLOOK.
