The TLOOK error has special significance. TLOOK is set if an XTI/TLI routine is interrupted by an unexpected asynchronous transport event on the endpoint. TLOOK does not report an error with an XTI/TLI routine, but the normal processing of the routine is not done because of the pending event. The events defined by XTI/TLI are listed in Table 3-7.
Table 3-7 Asynchronous Endpoint Events|
Name |
Description |
T_LISTEN |
Connection request arrived at the transport endpoint |
T_CONNECT |
Confirmation of a previous connect request arrived (generated when a server accepts a connect request) |
T_DATA |
User data has arrived |
T_EXDATA |
Expedited user data arrived |
T_DISCONNECT |
Notice that an aborted connection or a rejected connect request arrived |
T_ORDREL |
A request for orderly release of a connection arrived |
T_UDERR |
Notice of an error in a previous datagram arrived. (See "Read/Write Interface".) |
The state table in "State Transitions" shows which events can happen in each state. t_look() lets a user determine what event has occurred if a TLOOK error is returned. In the example, if a connect request is rejected, the client exits.
