The following markup defines a simple hyperlink to a topic with the ID Intro. Notice that capitalization of the ID is not significant.
<s1 id=Intro>Introducing the Desktop . . . Refer to the <link intro>Introduction<\link>.
The following markup defines the same hyperlink jump as in the previous example but the <link> element is not used because a cross-reference (<xref...>) is automatically a hyperlink. In this case, the title of the Intro topic is automatically supplied by HelpTag.
Refer to <xref intro>.
This markup produces this output:
Refer to Introducing the Desktop.
The following markup defines a hyperlink that is activated when the inline graphic is chosen. A new window is opened to display the "clockfeatures" topic.
Whenever you see the <link clockfeatures JumpNewView> <graphic entity=StopWatchIcon><\link> symbol, stop and answer the quiz questions.
It produces this output:
The following markup creates a link that displays the man page for the grep command:
For more details, refer to the <link grep Man>grep man page<\link>.
The following markup creates an execution link using an execution alias named startDtterm. The alias name and the command it executes are defined in the application's application defaults file.
To open a terminal window, click <link hyperlink="DtHelpExecAlias startDtterm" Execute>Start Terminal Emulator.<\link>
For information about execution aliases and how to define them, see "Execution Aliases".
