Korean text can be written using a phonetic writing system called Hangul. Hangul has more than 11,000 characters, which are composed by 19 consonants, 21 vowels and optional 27 consonants. About 3,000 Hangul characters from the whole Hangul characters are usually used in Korean computer systems. Korean also uses ideographs based on the set invented in China, called Hanja. Korean text requires over 6,000 Hanja characters. Hanja is used mostly to avoid confusion when Hangul would be ambiguous. Hangul characters are formed by combining consonants and vowels. After combining them together, they can compose one syllable, which is a Hangul character. Hangul characters are often arranged in a square, so that the group takes up the same space as a Hanja character. Arabic numerals, Roman letters and special symbol characters are also present in Korean text.
