To ensure correct text edit operation by a terminal or by a terminal emulator such as dtterm(1), users should push certain locale-specific STREAMS modules onto their Streams.
For more information on STREAMS modules and streams in general, see the STREAMS Programming Guide.
Table 4-1 shows STREAMS modules supported by the en_US.UTF-8 locale in the terminal environment:
Table 4-1 32-bit STREAMS Modules Supported by en_US.UTF-8
Table 4-2 lists the 64-bit STREAMS Modules Supported by en_US.UTF-8.
Table 4-2 64-bit STREAMS Modules Supported by en_US.UTF-8|
64-bit STREAMS module |
Description |
/usr/kernel/strmod/sparcv9/eucu8 |
UTF-8 STREAMS module for tail side |
/usr/kernel/strmod/sparcv9/u8euc |
UTF-8 STREAMS module for head side |
/usr/kernel/strmod/sparcv9/u8lat1 |
Code conversion STREAMS module betweenUTF-8 and ISO 8859-1 (Western European) |
/usr/kernel/strmod/sparcv9/u8lat2 |
Code conversion STREAMS module between UTF-8 and ISO 8859-2 (Eastern European) |
/usr/kernel/strmod/sparcv9/u8koi8 |
Code conversion STREAMS module betweenUTF-8 and KOI8-R (Cyrillic) |
To load a STREAMS module at kernel, first become root:
system% su Password: system# |
To determine whether you are running a 32-bit Solaris or 64-bit Solaris system, use the isainfo(1) utility as follows:
system# isainfo -v 64-bit sparcv9 applications 32-bit sparc applications system# |
If the command returns this information, you are running the 64-bit Solaris system. If you are running the 32-bit Solaris system, the utility shows the following:
system# isainfo -v 32-bit sparc applications system# |
Use modinfo(1M) to be certain that your system has not already loaded the STREAMS module:
system# modinfo | grep eucu8modulename |
If the STREAMS module, such as eucu8, is already installed, the output will look as follows:
system# modinfo | grep eucu8 89 ff798000 4b13 18 1 eucu8 (eucu8 module) system# |
If the module is already installed, you don't need to load it. However, if the module has not yet been loaded, use modload(1M)as follows:
system# modload /usr/kernel/strmod/eucu8modulename |
This loads the 32-bit eucu8 STREAMS module at the kernel, so you can push it onto a Stream. If you are running the 64-bit Solaris product, use modload(1M) as follows:
system# modload /usr/kernel/strmod/sparcv9/eucu8 |
The STREAMS module is installed at the kernel, and you can now push it onto a Stream.
To unload a module from the kernel, use modunload(1M), as shown below. In this example, the eucu8 module is being unloaded.
system# modinfo | grep eucu8 89 ff798000 4b13 18 1 eucu8 (eucu8 module) system# modunload -i 89 |
The dtterm(1) and any terminal that supports input and output of the UTF-8 codeset should have the following STREAMS configuration:
head <-> ttcompat <-> u8euc <-> ldterm <-> eucu8 <-> pseudo-TTY |
In this example, u8euc and eucu8 are the modules supported by the en_US.UTF-8 locale. Make sure you already loaded the STREAMS modules into the kernel as specified in the previous section.
To set up the above STREAMS configuration, use,strchg(1) as shown below:
system% cat > /tmp/mystreams ttcompat u8euc ldterm eucu8 ptem ^D system% strchg -f /tmp/mystreams |
When using strchg(1) , be sure you are either root or the owner of the device. To see the current configuration of STREAMS, use strconf(1) as shown below:
system% strconf ttcompat u8euc ldterm eucu8 ptem pts system% |
To revert to the original configuration, set the STREAMS configuration again as shown below:
system% cat > /tmp/orgstreams ttcompat ldterm ptem ^D system% strchg -f/tmp/orgstreams |
For terminals that support only Latin-1 (ISO 8859-1), Latin-2 (ISO 8859-2), or KOI8-R, you should have the following STREAMS configuration:
head <-> ttcompat <-> u8euc <-> ldterm <-> eucu8 <-> u8lat1 <-> TTY |
This configuration is only for terminals that support Latin-1. For Latin-2 terminals, replace the STREAMS module u8lat1 with u8lat2. For KOI8-R terminals, replace the module with u8koi8.
To set up the STREAMS configuration shown above, use strchg(1), as follows:
system% cat > tmp/mystreams ttcompat u8euc ldterm eucu8 u8lat1 ptem ^D system% strchg -f /tmp/mystreams |
Be sure that you are either root or the owner of the device when you use strchg(1). To see the current configuration, usestrchg(1) , as follows:
system% strconf ttcompat u8euc ldterm eucu8 u8lat1 ptem pts system% |
To revert to the original configuration, set the STREAMS configuration as follows:
system% cat > /tmp/orgstreams ttcompat ldterm ptem ^D system% strchg -f /tmp/orgstreams |
To set up the UTF-8 text edit behavior on TTY, you must first set some terminal options using stty(1) as follows:
system% /bin/stty cs8 -istrip defeucw |
Since /usr/ucb/stty is not yet internationalized, you should use /bin/stty instead.
You can also query the current settings using stty(1) with the -a option, as shown below:
system% /bin/stty -a |
Assuming the necessary STREAMS modules are already loaded with the kernel, you can save the following lines in your .cshrc file (C shell example) for convenience:
setenv LANG en_US.UTF-8 if ($?USER != 0 && $?prompt != 0) then cat >! /tmp/mystreams$$ << _EOF ttcompat u8euc ldtterm eucu8 ptem _EOF /bin/strchg -f /tmp/mystream$$ /bin/rm -f /tmp/mystream$$ /bin/stty cs8 -istrip defeucw endif |
With these lines in your.cshrc file, you do not have to type all of the commands each time. Note that the second _EOF should be in the first column of the file. You can also create a file called mystreams and save it so the .cshrc references to mystreams instead of creating it whenever you start a C shell.
