The vtsk command starts the SunVTS kernel. You can use command-line options (see Table 3-3 below) to control the behavior of this command.
For systems running in the 32-bit Solaris environment, use the following command:
| # /opt/SUNWvts/bin/vtsk |
For systems running in the 64-bit Solaris environment, use the following command:
| # /opt/SUNWvts/bin/sparcv9/vtsk |
The vtsk command-line syntax and options are listed below:
Table 3-3 The vtsk Syntax|
/opt/SUNWvts/bin/vtsk [-epqsv] [-o options_file] [-f logfile_directory] |
Argument |
Description |
-e |
Disables the connection permission checking feature |
-f logfile_directory* |
Specifies an alternative to the default logfile directory (/var/opt/SUNWvts/logs) |
-o options_file |
Starts the SunVTS kernel with the test options saved in the options_file; these options are saved and stored in the /var/opt/SUNWvts/options directory |
-p |
Starts the SunVTS kernel, but does not probe test system devices |
-q |
Quits both the SunVTS kernel and the user interface when testing is complete |
-s |
Starts testing a selected group of tests; this flag must be used with the -o options_file flag |
-v |
Displays only the version information from the SunVTS kernel, vtsk; this option does not start the vtsk daemon |
* If the -f option is exercised when running SyMON, a logfile directory cannot be created. |
