SPARC Assembly Language Reference Manual
2.3.8 Operators and Expressions
The operators described in Table 2-3Table 2-3 are recognized in constant expressions.
Table 2-3
Binary
Operators
Unary
Operators
Integer addition
(No effect)
Integer subtraction
2's Complement
Integer multiplication
1's Complement
Integer division
%lo(address)
Extract least significant 10 bits as computed by: (address & 0x3ff)
Modulo
%hi(address)
Extract most significant 22 bits as computed by: (address >>10)
Exclusive OR
%r_disp32
%r_disp64
Used in Sun compiler-generated code only to instruct the assembler to generate specific relocation information for the given expression.
Left shift
%r_plt32
%r_plt64
Right shift
Bitwise AND
Bitwise OR
Since these operators have the same precedence as in the C language, put expressions in parentheses to avoid ambiguity.
To avoid confusion with register names or with the %hi, %lo, %r_disp32/64, or %r_plt32/64 operators, the modulo operator % must not be immediately followed by a letter or digit. The modulo operator is typically followed by a space or left parenthesis character.
