Special symbol names begin with a percentage sign (%) to avoid conflict with user symbols. Table 2-2Table 2-2 lists these special symbol names.
Table 2-2|
Symbol Object |
Name |
Comment |
General-purpose registers |
%r0 ... %r31 |
General-purpose global registers |
%g0 ... %g7 |
Same as %r0 ... %r7 |
General-purpose out registers |
%o0 ... %o7 |
Same as %r8 ... %r15 |
General-purpose local registers |
%l0 ... %l7 |
Same as %r16 ... %r23 |
General-purpose in registers |
%i0 ... %i7 |
Same as %r24 ... %r31 |
Stack-pointer register |
%sp |
(%sp = %o6 = %r14) |
Frame-pointer register |
%fp |
(%fp = %i6 = %r30) |
Floating-point registers |
%f0 ... %f31 |
Floating-point status register |
%fsr |
Front of floating-point queue |
%fq |
Coprocessor registers |
%c0 ... %c31 |
Coprocessor status register |
%csr |
Coprocessor queue |
%cq |
Program status register |
%psr |
Trap vector base address register |
%tbr |
Window invalid mask |
%wim |
Y register |
%y |
Unary operators |
%lo |
Extracts least significant 10 bits |
%hi |
Extracts most significant 22 bits |
%r_disp32 |
Used only in Sun compiler-generated code. |
%r_plt32 |
Ancillary state registers |
%asr1 ... %asr31 |
There is no case distinction in special symbols; for example,
%PSR
is equivalent to
%psr
The suggested style is to use lowercase letters.
The lack of case distinction allows for the use of non-recursive preprocessor substitutions, for example:
#define psr %PSR
The special symbols %hi and %lo are true unary operators which can be used in any expression and, as other unary operators, have higher precedence than binary operations. For example:
%hi a+b = (%hi a)+b %lo a+b = (%lo a)+b
To avoid ambiguity, enclose operands of the %hi or %lo operators in parentheses. For example:
%hi(a) + b
