Unless otherwise specified, floating-point registers contain all instruction operands. There are 32 double-precision registers. Single-precision floating-point registers contain the pixel values, and double-precision floating-point registers contain the fixed values.
The opcode space reserved for the Implementation-Dependent Instruction1 (IMPDEP1) instructions is where the graphics instruction set is mapped.
Partitioned add/subtract instructions perform two 32-bit or four 16-bit partitioned adds or subtracts between the source operands corresponding fixed point values.
Table E-15|
SPARC |
Mnemonic |
Argument List |
Description |
FPADD16 FPADD16S FPADD32 FPADD32S FPSUB16 FPSUB16S FPSUB32 FPSUB32S |
fpadd16 fpadd16s fpadd32 fpadd32s fpsub16 fpsub16s fpsub32 fpsub32s |
fregrs1, fregrs2, fregrd fregrs1, fregrs2, fregrd fregrs1, fregrs2, fregrd fregrs1, fregrs2, fregrd fregrs1, fregrs2, fregrd fregrs1, fregrs2, fregrd fregrs1, fregrs2, fregrd fregrs1, fregrs2, fregrd |
four 16-bit add two 16-bit add two 32-bit add one 32-bit add four 16-bit subtract two 16-bit subtract two 32-bit subtract one 32-bit subtract |
Pack instructions convert to a lower pixel or precision fixed format.
Table E-16|
SPARC |
Mnemonic |
Argument List |
Description |
FPACK16 FPACK32 FPACKFIX FEXPAND FPMERGE |
fpack16 fpack32 fpackfix fexpand fpmerge |
fregrs2, fregrd fregrs1, fregrs2, fregrd fregrs2, fregrd fregrs2, fregrd fregrs1, fregrs2, fregrd |
four 16-bit packs two 32-bit packs four 16-bit packs four 16-bit expands two 32-bit merges |
Partitioned multiply instructions have the following variations.
Table E-17|
SPARC |
Mnemonic |
Argument List |
Description |
FMUL8x16 FMUL8x16AU FMUL8x16AL FMUL8SUx16 FMUL8ULx16 FMULD8SUx16 FMULD8ULx16 |
fmul8x16 fmul8x16au fmul8x16al fmul8sux16 fmul8ulx16 fmuld8sux16 fmuld8ulx16 |
8x16-bit partition 8x16-bit upper partition 8x16-bit lower partition upper 8x16-bit partition lower unsigned 8x16-bit partition upper 8x16-bit partition lower unsigned 8x16-bit partition |
Alignment instructions have the following variations.
Table E-18|
SPARC |
Mnemonic |
Argument List |
Description |
ALIGNADDRESS ALIGNADDRESS_LITTLE FALIGNDATA |
alignaddr alignaddrl
faligndata |
regrs1, regrs2, regrd regrs1, regrs2, regrd
find misaligned data access address same as above, but little-endian
do misaligned data, data alignment |
Logical operate instructions perform one of sixteen 64-bit logical operations between rs1 and rs2 (in the standard 64-bit version).
Table E-19|
SPARC |
Mnemonic |
Argument List |
Description |
FZERO FZEROS FONE FONES FSRC1 |
fzero fzeros fone fones fsrc1 |
fregrd fregrd fregrd fregrd fregrs1, fregrd |
zero fill zero fill, single precision one fill one fill, single precision copy src1 |
FSRC1S FSRC2 FSRC2S FNOT1 FNOT1S |
fsrc1s fsrc2 fsrc2s fnot1 fnot1s |
fregrs1, fregrd fregrs2, fregrd fregrs2, fregrd fregrs1, fregrd fregrs1, fregrd |
copy src1, single precision copy src2 copy src2, single precision negate src1, 1's complement same as above, single precision |
FNOT2 FNOT2S FOR FORS FNOR |
fnot2 fnot2s for fors fnor |
fregrs2, fregrd fregrs2, fregrd fregrs1, fregrs2, fregrd fregrs1, fregrs2, fregrd fregrs1, fregrs2, fregrd |
negate src2, 1's complement same as above, single precision logical OR logical OR, single precision logical NOR |
FNORS FAND FANDS FNAND FNANDS |
fnors fand fands fnand fnands |
logical NOR, single precision logical AND logical AND, single precision logical NAND logical NAND, single precision |
FXOR FXORS FXNOR FXNORS FORNOT1 |
fxor fxors fxnor fxnors fornot1 |
logical XOR logical XOR, single precision logical XNOR logical XNOR, single precision negated src1 OR src2 |
FORNOT1S FORNOT2 FORNOT2S FANDNOT1 |
fornot1s fornot2 fornot2s fandnot1 |
same as above, single precision src1 OR negated src2 same as above, single precision negated src1 AND src2 |
FANDNOT1S FANDNOT2 FANDNOT2S |
fandnot1s fandnot2 fandnot2s |
same as above, single precision src1 AND negated src2 same as above, single precision |
Pixel compare instructions compare fixed-point values in rs1 and rs2 (two 32 bit or four 16 bit)
Table E-20|
SPARC |
Mnemonic |
Argument List |
Description |
FCMPGT16 FCMPGT32 FCMPLE16 FCMPLE32 |
fcmpgt16 fcmpgt32 fcmple16 fcmple32 |
fregrs1, fregrs2, regrd fregrs1, fregrs2, regrd fregrs1, fregrs2, regrd fregrs1, fregrs2, regrd |
4 16-bit compare, set rd if src1>src2 2 32-bit compare, set rd if src1>src2 4 16-bit compare, set rd if src1<=src2 2 32-bit compare, set rd if src1<=src2 |
FCMPNE16 FCMPNE32 FCMPEQ16 FCMPEQ32 |
fcmpne16 fcmpne32 fcmpeq16 fcmpeq32 |
4 16-bit compare, set rd if src1[ne ]src2 2 32-bit compare, set rd if src1[ne ]src2 4 16-bit compare, set rd if src1=src2 2 32-bit compare, set rd if src1=src2 |
Edge handling instructions handle the boundary conditions for parallel pixel scan line loops.
Table E-21|
SPARC |
Mnemonic |
Argument List |
Description |
EDGE8 EDGE8L EDGE16 |
edge8 edge8l edge16 |
regrs1, regrs2, regrd regrs1, regrs2, regrd regrs1, regrs2, regrd |
8 8-bit edge boundary processing same as above, little-endian 4 16-bit edge boundary processing |
EDGE16L EDGE32 EDGE32L |
edge16l edge32 edge32l |
same as above, little-endian 2 32-bit edge boundary processing same as above, little-endian |
Pixel component distance instructions are used for motion estimation in video compression algorithms.
Table E-22|
SPARC |
Mnemonic |
Argument List |
Description |
PDIST |
pdist |
8 8-bit components, distance between |
The three-dimensional array addressing instructions convert three- dimensional fixed-point addresses (in rs1) to a blocked-byte address.The result is stored in rd.
Table E-23|
SPARC |
Mnemonic |
Argument List |
Description |
ARRAY8
ARRAY16 ARRAY32 |
array8
array16 array32 |
convert 8-bit 3-D address to blocked byte address same as above, but 16-bit same as above, but 32-bit |
