These memory access instructions are part of the SPARC-V9 instruction set extensions.
Table E-24|
SPARC |
imm_asi |
Argument List |
Description |
STDFA STDFA STDFA STDFA |
ASI_PST8_P ASI_PST8_S ASI_PST8_PL ASI_PST8_SL |
stda fregrd, [fregrs1] regmask, imm_asi |
eight 8-bit conditional stores to: primary address space secondary address space primary address space, little endian secondary address space, little endian |
ASI_PST16_P ASI_PST16_S ASI_PST16_PL ASI_PST16_SL |
four 16-bit conditional stores to: primary address space secondary address space primary address space, little endian secondary address space, little endian |
ASI_PST32_P ASI_PST32_S ASI_PST32_PL ASI_PST32_SL |
two 32-bit conditional stores to: primary address space secondary address space primary address space, little endian secondary address space, little endian |
To select a partial store instruction, use one of the partial store ASIs with the STDA instruction.
SPARC |
imm_asi |
Argument List |
Description |
LDDFA STDFA |
ASI_FL8_P |
ldda [reg_addr] imm_asi, freqrd stda freqrd, [reg_addr] imm_asi |
8-bit load/store from/to: primary address space |
LDDFA STDFA |
ASI_FL8_S |
ldda [reg_plus_imm] %asi, freqrd stda [reg_plus_imm] %asi |
secondary address space |
LDDFA STDFA |
ASI_FL8_PL |
primary address space, little endian |
LDDFA STDFA |
ASI_FL8_SL |
LDDFA STDFA |
ASI_FL16_P |
16-bit load/store from/to: primary address space |
LDDFA STDFA |
ASI_FL16_S |
LDDFA STDFA |
ASI_FL16_PL |
LDDFA STDFA |
ASI_FL16_SL |
To select a short floating-point load and store instruction, use one of the short ASIs with the LDDA and STDA instructions.
SPARC |
imm_asi |
Argument List |
Description |
LDDA LDDA |
ASI_NUCLEUS_QUAD_LDD ASI_NUCLEUS_QUAD_LDD_L |
[reg_addr] imm_asi, regrd [reg_plus_imm] %asi, regrd |
128-bit atomic load 128-bit atomic load, little endian |
LDDFA STDFA |
ASI_BLK_AIUP |
64-byte block load/store from/to: primary address space, user privilege |
LDDFA STDFA |
ASI_BLK_AIUS |
ldda [reg_plus_imm] %asi, freqrd stda fregrd, [reg_plus_imm] %asi |
secondary address space, user privilege. |
LDDFA STDFA |
ASI_BLK_AIUPL |
primary address space, user privilege, little endian |
LDDFA STDFA |
ASI_BLK_AIUSL |
secondary address space, user privilege little endian |
LDDFA STDFA |
ASI_BLK_P |
LDDFA STDFA |
ASI_BLK_S |
LDDFA STDFA |
ASI_BLK_PL |
LDDFA STDFA |
ASI_BLK_SL |
LDDFA STDFA |
ASI_BLK_COMMIT_P |
64-byte block commit store to primary address space |
LDDFA STDFA |
ASI_BLK_COMMIT_S |
64-byte block commit store to secondary address space |
To select a block load and store instruction, use one of the block transfer ASIs with the LDDA and STDA instructions.
