Solaris 7 (Intel Platform Edition) Device Configuration Guide
Supported Settings
If your card supports Plug and Play, your device resources are configured automatically. Use the following settings for devices that don't support Plug and Play. Defaults are shown in this typeface.
Compaq Deskpro XL Business Audio With Built-in AD1847 Chip
o I/O Address:
0x530, 0x604, 0xE80, 0xF40
The sbpro driver automatically chooses an unused DMA channel and IRQ line for the device.
Note -
The sbpro support for the AD1848 and compatibles uses one DMA channel for both play and record; simultaneous play/record is not supported.
Turtle Beach Tropez Card With CS4231 Chip
o I/O Address:
0x530
The MWSS I/O address on the Turtle Beach Tropez card is 0x530 at power-up. It can only be changed by software after the system is booted, and the Solaris operating environment does not do that. Therefore, the Tropez card is only supported at I/O address 0x530.
Note -
The Tropez card comes with a software utility for selecting the IRQ, DMA, and MWSS compatibility I/O address settings used by the card. However, that utility does not record those parameters in nonvolatile memory, but in a configuration file used by DOS to set the card's configuration at each reboot. This type of configuration file is not used by the Solaris software and does not affect the operation of the card with the Solaris operating environment.
