If you want to remove the disk, you must unmount the file system.
If you want to create a pcfs file system, use a DOS machine. To mount a pcfs file system, type:
| # mount -F pcfs /dev/dsk/c#d#p0:c /mnt |
For more information, see the pcfs(7FS) and mount(1M) man pages.
If you want to create a ufs file system, use the newfs command and type:
| # newfs /dev/rdsk/c#d#s# |
To mount a ufs file system, type:
| # mount -F ufs /dev/dsk/c#d#s# /mnt |
For more information, see the newfs(1M) andmount(1M) man pages.
To create a Solaris partition, run the format command and go to the Partition menu. For more information, see the format(1M) man page.
