You must use the settings in this typeface for the DPT adapter if an IDE controller is installed:
o I/O Address: |
0x1F0, 0x230 |
o IRQ Level: |
12, 14, 15 |
o DMA Channel: |
5, 6 |
o Emulation: |
Disabled |
Follow the instructions in "DPT PM2022, PM2042W, PM2122, PM2142W SCSI and PM3222, PM3222UW, PM3332UW SCSI RAID HBAs" to disable WD1003 emulation using the DPT SCSI Storage Manager Utility diskette.
Emulation mode for drives 0 and 1 should be set to 0 indicating "no drives present," or there will be missing drives when the system boots.
Use edge-triggered interrupts on the PM2011.
The PM2041W adapter's SmartROM must be upgraded to at least version 3DL in place of 3D0. The BIOS on adapters with version 3D0 does not detect any devices connected to it.
