DPT PM3224 only: The EPROM should not be earlier than version 7A.
DPT PM2024 and PM2124 only: The EPROM should not be earlier than version 6D4.
Don't use an adapter with a SmartROM earlier than version 3.B.
Ensure that the controller board is installed in a PCI bus-mastering slot.
If the firmware version of the controller is earlier than 7A, or if your computer memory is ECC or does not check parity, disable PCI parity checking.
During the system boot, if you see a message that a DPT controller driver cannot be installed, the motherboard installed in your system probably has ECC memory or does not check parity; disable PCI parity checking.
o I/O Address: |
Auto |
