System Interface Guide
User Priority Inversion
There is no mechanism by which processes synchronizing with other processes will automatically inherit the priority of waiting processes. An application can bound its priority inversion by using priority ceiling emulation.
Under this model, the application associates a priority with each synchronization object, which is typically the highest priority of any process that can block on that object.
Each process then uses the following sequence when manipulating the shared resources:
