After the endpoint has been established using t_open(3N), and its identity established using t_bind(3N), the endpoint can be configured for asynchronous service. This is done by using the fcntl(2) function to set the O_NONBLOCK flag on the endpoint. Thereafter, calls to t_sndudata(3N) for which no buffer space is immediately available return -1 with t_errno set to TFLOW. Likewise, calls to t_rcvudata(3N) for which no data are available return -1 with t_errno set to TNODATA.
