System Interface Guide
Asynchronous Network Transfers
Although an application can use the poll(2) function to check periodically for the arrival of data or to wait for the receipt of data on an endpoint, it might be necessary to receive asynchronous notification when data has arrived. This can be done by using the ioctl(2) function with the I_SETSIG command to request that a SIGPOLL signal be sent to the process upon receipt of data at the endpoint. Applications should check for the possibility of multiple messages causing a single signal.
In the following example, protocol is the name of the application-chosen transport protocol.
#include <sys/types.h>
#include <tiuser.h>
#include <signal.h>
#include <stropts.h>
int				fd;
struct t_bind				*bind;
void				sigpoll(int);
	fd = t_open(protocol, O_RDWR, (struct t_info *) NULL);
	bind = (struct t_bind *) t_alloc(fd, T_BIND, T_ADDR);
	...     /* set up binding address */
	t_bind(fd, bind, bin
	/* make endpoint non-blocking */
	fcntl(fd, F_SETFL, fcntl(fd, F_GETFL) | O_NONBLOCK);
	/* establish signal handler for SIGPOLL */
	signal(SIGPOLL, sigpoll);
	/* request SIGPOLL signal when receive data is available */
	ioctl(fd, I_SETSIG, S_INPUT | S_HIPRI);
void sigpoll(int sig)
	int					flags;
	struct t_unitdata					ud;
	for (;;) {
		... /* initialize ud */
		if (t_rcvudata(fd, &ud, &flags) < 0) {
			if (t_errno == TNODATA)
				break;  /* no more messages */
			... /* process other error conditions */
	... /* process message in ud */
