ToolTalk User's Guide
Joining Multiple Sessions
When you join multiple sessions, you will automatically get responses to requests and point-to-point messages but you will not get notices unless you explicitly join the new session. The following code sample shows how to join the multiple sessions.
tt_default_session_set(new_session_identifier);
tt_open();
tt_session_join(new_session);
In order to effectively use multiple sessions, you must store the session ids of the sessions in which you are interested in order to pass these identifiers to tt_default_session_set prior to opening a new session with tt_open; that is, you need to place the values (which ttsession stores in the environment variable _SUN_TT_SESSION) in a file on the system so that other ToolTalk clients can access the value of a session id contained in that file and use it to open the non-default session. For example, you can store the session ids in a "well-known" file and then send a file-scoped message (indicating this file) to all clients which have registered an appropriate pattern. The client will then know to open the scoped-to file, read one or more session ids from it, and use these session ids (with tt_open) to open a non-default session. An alternative method is advertising the session ids by means of, for example, a name service or a third-party database.
Note -
How ttsession session ids are stored and passed to interested clients is beyond the scope of the ToolTalk protocol and must be determined based on the architecture of the system.
