ToolTalk User's Guide
Joining Files of Interest
When you join a file, the ToolTalk service automatically adds the name of the file to your file-scoped message patterns. For example, if you have declared a process type or registered a message pattern that specifies TT_FILE or TT_FILE_IN_SESSION, use the tt_file_join function() to join files of interested. Table 9-3 lists the ToolTalk functions you use to express your interest in specific files.
Table 9-3 ToolTalk Functions for Joining Files of Interest
Return Type
ToolTalk Function
Description
char *
tt_default_file(void)
Join default file
Tt_status
tt_default_file_set(const char *docid)
Set default file
Tt_status
tt_file_join(const char *filepath)
Join this file
Tt_status
tt_file_quit(const char *filepath)
Quit file
When you no longer want to receive messages that reference the file, use the tt_file_quit() function to remove the file name from your file-scoped message patterns.
