install4x は、次のような Install Main Menu を表示します。
*** 4.1* Install Main Menu ***
Choose an Architecture (then select modules to load):
Modules
Selected Loaded
[a] sun4.sun4c.sunos.4.1.2 8 0
[b] sun4.sun4.sunos.4.1.2 8 0
[c] sun4.sun4m.sunos.4.1.2 7 0
or begin the loading process for all selected modules:
[L] Load selected module +----------------------+
| Disk Usage: |
or abort without loading any modules | 0K Selected |
| 53634K Free |
[Q] Quit without loading +----------------------+
Type any bracketed letter to select that function.
Type ? for help.
Install Main Menu 画面にはいくつかのオプションがあります。最初の設定 (ここでは a、b、c で表示) は、ソフトウェアをロードするアーキテクチャを指定するのに使用します。他のオプションを使用してユーザは、ソフトウェアのロードの開始 (L)、プログラムの中止 (Q)、ヘルプの表示 (?) を選択できます。
適切なアーキテクチャを選択した後、プログラムは Module Selection を表示します。
Select sun4.sun4c.sunos.4.1.2 modules: +[a] R proto root.............240K | [o] User_Diag.................6352K +[a] R proto root.............240K | [o] User_Diag.................6352K +[b] R usr..................26240K | [p] Manual....................7456K +[c] R Kvm...................4832K | +[q] D TLI.........................48K +[d] R Install................936K | [r] D RFS........................912K [e] D Networking.............1040K | [s] D Debugging.................2928K [f] D System_V...............4008K | [t] SunView_Programmers.......1840K [g] D Sys....................5288K | [u] Shlib_Custom..............1376K [h] C SunView_Users..........2664K | [v] Graphics..................1784K [i] SunView_Demo............512K | +[w] uucp.......................608K +[j] Text...................712K | +[x] Games.....................3136K [k] Demo..................4264K | [y] Versatec..................5960K [l] C OpenWindows_Users.....25936K | [z] Security...................312K [m] C OpenWindows_Demo.......4288K | [A] OpenWindows_Programmers..10200K [n] C OpenWindows_Fonts......7840K | Module + = already loaded R = Required C= Common Legend: ** = selected for loading D = Desirable Others are optional Select [a-A] or a Quick-Pick Option: +-------------------+ [1] All Required Modules [4] All Optional Modules | Disk Usage: | [2] All Desirable Modules [5] All Modules | 0K Selected | [3] All Common Modules | 53634K Free | or [D] (done) to return to the main screen +-------------------+
すでにロードされているパッケージは、Module Selection 画面の選択文字の前に + を付けて表示されます (つまり、上記の画面で a、b、c、d、j、q、w、x に対応するパッケージはすでにロードされています)。多数のパッケージが共用されているため、1 つのアーキテクチャ用にパッケージをロードするときに、それらのパッケージが他のアーキテクチャ用に「ロードされている」と表示される場合がありますので注意してください。
角括弧内の文字を入力して、ロードするモジュールを選択します。モジュールに関連付けられているキーを押すと、選択状態を切り替えます (つまり、前の状態によって、モジュールを選択したり、選択を解除したりします)。ロードするよう選択されたモジュールには、選択文字の前に ** が表示されます。明らかに重複する処理ですが、プロンプトに対して Y または y で応答すると、現在あるモジュールを再度ロードすることができます。
サンでは、リリースが正常に動作するためにロードしなければならないソフトウェア (選択文字の右に R を表示)、一般にロードされるソフトウェア (C を表示)、ロードするのが望ましいソフトウェア (D を表示) を決めています。
さらに、Module Selection 画面では、ロードするモジュールのグループを簡単に選択できます。1 を入力すると、ロードに必要なすべてのモジュールがマークされます。2 を入力すると、推奨されるすべてのモジュールがマークされます。3 を入力すると、通常ロードされるすべてのモジュールがマークされます。4 を入力すると、すべてのオプションモジュールがマークされます。5 を入力すると、Module Selection 画面に表示されるすべてのモジュールがマークされます。
D を入力して、Install Main Menu に戻ります。
Modules
Selected Loaded
[L] Load selected modules +-------------------+
| Disk Usage: |
or abort without loading any modules: | 0K Selected |
| 53634K Free |
[Q] Quit without loading +-------------------+
Type ? for help.
Install Main menu で L を入力すると、選択したすべてのモジュールをロードできます。次のような出力が表示されます。
Installing module `proto root' [size: 248K]
in directory /export/exec/proto.root.sunos.4.1.2 ...
Updating server databases ...
Press any key to continue:
