If you deploy centralized calendar services where users have access to their Calendar from a remote centralized server, then the Calendar requires about ten times the total size of Calendar files in swap space to work reliably.
For example, if users want to have access to Calendar from the same server and the Calendar files' size totals 50 MB, then Calendar requires 500 MB of swap space to work reliably.
If these space limitations are not considered during the installation of Solaris, users may have unreliable access to the Calendar.
Workaround: Increase swap space to enable the Calendar to work reliably.
