The fixed-width integer types provided by <inttypes.h> include both signed and unsigned integer types, such as int8_t, int16_t, int32_t, int64_t, uint8_t, uint16_t, uint32_t, and uint64_t. Derived types defined as the smallest integer types that can hold the specified number of bits, include int_least8_t,..., int_least64_t, uint_least8_t,..., uint_least64_t.
These fixed-width types should not be used indiscriminately. For example, int can continue to be used for such things as loop counters and file descriptors, and long can be used for array indexes. On the other hand, use fixed-width types for explicit binary representations of:
On-disk data
Over-the-wire data
Hardware registers
Binary interface specifications
Binary data structures
