Solaris 7 5/99 Release Notes (Intel Platform Edition)
Remote Login From dtgreet Freezes Local Window System (4213502)
If you select Remote Login from the main CDE login menu by clicking the Options button, a login to another host system occurs. When you terminate the remote login session and return to the original system, the screen freezes. To start another CDE session on a hung screen, log in remotely to the system and kill the hung DT session.
Workaround: Apply patch ID 107181-05 or later to prevent this problem. This patch is available through approved Sun support channels.
