When your primary enterprise-level name service is NIS, there is only one domain for the enterprise. Namespace contexts are created for that enterprise-wide domain.
The NIS domain must already exist.
The fncreate command must be run by root on the FNS master server. (Normally, this would be the NIS master server, but you could choose to use a different server.)
For example, create the contexts for the doc.com domain, on the machine named fns_master, which is also the NIS master server:
On the domain master, run fncreate as shown below:
fns_master# fncreate -t org org// |
This creates the organization context for the NIS domain doc.com, and contexts and associated subcontexts for all users found in NIS servers's passwd map and all hosts found in the server's hosts map.
After you have created your context maps, you can assign the same machine to be the master server, using the same procedure that you would to assign a different master for any other NIS map. The FNS maps all have names starting with fns_ and ending with either .ctx or .attr. See Solaris Naming Administration Guide for details.
