When your primary enterprise-level name service is NIS+, namespace contexts must be created separately for each NIS+ domain or subdomain in your enterprise.
The NIS+ domain or subdomain must already exist.
If you intend to use the same server for both NIS+ and FNS, you must run the fncreate command on the domain's (or subdomain's) master server. If you intend to use different servers for NIS+ and FNS, you must run the fncreate command on the machine that will function as the FNS server. (If you are going to use different machines, you must first prepare the FNS server, as explained in Step 4.)
You must have full NIS+ administration authorization (see Solaris Naming Administration Guide for information on NIS+ authorization).
For example, to create the contexts for the manf.doc.com subdomain on the submaster machine that is the NIS+ master server for that domain:
submaster# fncreate -t org org/manf.doc.com./ |
This creates the organization context for the NIS+ manf.doc.com. subdomain, and contexts and associated subcontexts for all users found in that subdomain's passwd.org_dir table and all hosts found in the subdomain's hosts.org_dir table.
(If you want to use different machines for NIS+ and FNS servers, run the above command on the machine you want to use as the FNS server. See Step 4 for information on how to prepare a non-NIS+ server to be an FNS server.)
