Solaris Naming Administration Guide
About Regular Expressions
Regular expressions are combinations of text and symbols that you can use to search for special configurations of column values. For example, the regular expression `Hello' searches for a value that begins with Hello. When using a regular expression in the command line, be sure to enclose it in quotes, since many of the regular expression symbols have special meaning to the Bourne and C shells. For example:
rootmaster% nisgrep -h greeting='Hello' phrases.doc.com.
The regular expression symbols are summarized in Table 14-7, below.
Table 14-7 Regular Expression Symbols
Symbol
Description
^string
Find a value that begins with string.
string $
Find a value that ends with string.
Find a value that has a number characters equal to the number of periods.
[chars]
Find a value that contains any of the characters in the brackets.
*expr
Find a value that has zero or more matches of the expr.
Find something that appears one or more times.
Find any value.
\'s-char'
Find a special character, such as ? or $.
x | y
Find a character that is either x or y.
