Solaris Naming Administration Guide
Syntax
To search through the first column, use:
nismatch string tablename
nisgrep reg-exp tablename
To search through a particular column, use:
nismatch column=string tablename
nisgrep column=reg-exp tablename
To search through multiple columns, use:
nismatch column=string tablename ...\
nismatch [column=string,...],tablename
nisgrep column=reg-exp ... \
   tablename
Table 14-8 nismatch and nisgrep Options
Option
Description
-c
Count. Instead of the entries themselves, displays a count of the entries that matched the search criteria.
-h
Header. Displays a header line above the entries, listing the name of each column.
-M
Master. Displays only the entries of the table stored on the master server. This ensures you get the most up-to-date information and should be used only for debugging.
