Example 28-14 shows the syntax for a pointer (PTR) resource record.
special-name [optional TTL] class PTR-real-name |
A pointer record allows special names to point to some other location in the domain. In the example, PTR's are used mainly in the in-addr.arpa. records for the translation of an address (the special name) to a real name. When translating an address, if the domain is fully qualified only the machine identification number need be specified. PTR names should be unique to the zone. The PTR records Example 28-15sets up reverse pointers for the special in-addr.arpa domain.
;special name [TTL] class PTR-real-name 1 IN PTR sirius.doc.com. |
