Become superuser.
Enable system message IDs by adding the following line to the /platform/`uname -i`/kernel/drv/log.conf file, if it exists. Otherwise, add the msgid property to the /kernel/drv/log.conf file.
msgid=1 |
Save and close the file.
Reboot the system by using the following command.
# init 6 |
To enable system message IDs without rebooting the system, use the following adb command:
# echo log_msgid/W1 | adb -kw |
