Become superuser.
Disable system message IDs by changing the msgid line in the /platform/`uname -i`/kernel/drv/log.conf file to the following, if it exists. Otherwise, change the msgid property to the /kernel/drv/log.conf file.
msgid=0 |
Save and close the file.
Reboot the system by using the following command.
# init 6 |
To disable system message IDs without rebooting the system, use the following adb command:
# echo log_msgid/W0 | adb -kw |
