The following events are not reported in the PDASync log file:
When you delete a record from the desktop, but modify that same record on the handheld device, the modified record appears on both the desktop and handheld device after synchronizing.
When you modify the same record on both the handheld device and the desktop, two records reflecting both modifications appear on both the handheld device and desktop after synchronizing.
In both cases, the PDASync application behaves correctly and exhibits the same behavior found in Palm's HotSync on a PC. Unlike HotSync, however, the PDASync application does not note this behavior in its log file.
