System Administration Guide: Basic Administration
Diskless Client Management Features
You can use the smosservice and smdiskless commands to add and maintain diskless client support on a network. By using a name service, you can manage system information in a centralized manner so that important system information, such as host names, does not have to be duplicated on every system in the network.
You can do the following tasks with the smosservice and smdiskless commands:
You can only use the diskless client commands to set up diskless client booting. You cannot use them to set up other services, such as remote installation or profile services. Set up remote installation services by including diskless client specifications in the sysidcfg file. For more information, see Solaris 9 Installation Guide.
Working With Diskless Client Commands
By writing your own shell scripts and using the commands shown in the following table, you can easily set up and manage your diskless client environment.
Table 7–3 Diskless Client Commands
Command
Subcommand
Task
/usr/sadm/bin/smosservice
add
Add OS services
delete
Delete OS services
list
List OS services
patch
Manage OS service patches
/usr/sadm/bin/smdiskless
add
Add a diskless client to an OS server
delete
Delete a diskless client from an OS server
list
List the diskless clients on an OS server
modify
Modify the attributes of a diskless client
You can obtain help on these commands in two ways:
Required RBAC Rights for Diskless Client Management
You can use the smosservice and smdiskless commands as superuser. If you are using Role-Based Access Control (RBAC), you can use of either a subset or all of the diskless client commands, according to the RBAC rights to which they are assigned. The following table lists the RBAC rights that are required to use the diskless client commands.
Table 7–4 Required Rights For Diskless Client Management
RBAC Right
Command
Task
Basic Solaris User, Network Management
smosservice list
List OS services
smosservice patch
List OS services patches
smdiskless list
List diskless clients
Network Management
smdiskless add
Add diskless clients
System Administrator
All commands
All tasks
Adding OS Services
A Solaris OS server is a server that provides operating system (OS) services to support diskless client systems. You can add support for an OS server or convert a standalone system to an OS server with the smosservice command.
For each platform group and Solaris release that you want to support, you must add the particular OS service to the OS server. For example, if you want to support SPARCTM Sun4m systems running the Solaris 8 release, you must add Sun4m/Solaris 8 OS services to the OS server. You would also still need to add OS services to support SPARC Sun4c systems or IA based systems that runs the Solaris 8 release, because they are different platform groups.
You must have access to the appropriate Solaris CD or disk image to add OS services.
Adding OS Services When the OS Server Has Been Patched
When adding OS services to an OS server, you might see error messages saying that you have inconsistent versions of the OS running on the server and the OS that you are trying to add. This message occurs when the installed version of the OS has packages that were previously patched and the OS services being added do not have those packages patched (because the patches have been integrated into the packages).
For example, you may have a server that is running the Solaris 7 release. You may also have additional OS services loaded on this server, including the Solaris 2.6 SPARC sun4m OS services that have been patched. If you try to add the Solaris 2.6 SPARC sun4c OS services from a CD-ROM to this server, you could get the following error message:
Error: inconsistent revision, installed package appears to have been
patched resulting in it being different than the package on your media.
You will need to backout all patches that patch this package before
retrying the add OS service option.
