read
Reads each sector on the current disk.
Repairs defective blocks as a default.
refresh
Reads then writes data on the current
disk without harming the data. Repairs defective blocks as a default.
test
Writes a set of patterns to the disk
write
then reads the data on the disk back. Destroys existing data on the disk.
compare
Writes a set of patterns to the disk,
reads the data back, and then compares it to the data in the write buffer.
Destroys existing data on the disk. Repairs defective blocks as a default.
purge
Removes all data from the disk so that
the data can't be retrieved by any means. Data is removed by writing three
distinct patterns over the entire disk (or a section of the disk). If the
verification passes, a hex-bit pattern is written over the entire disk (or
verify
Writes unique data to each block on
the entire disk in the first pass. Reads and verifies the data in the next
pass. Destroys existing data on the disk. Repairs defective blocks as a default.
print
Displays the data in the read/write
buffer.
setup
Lets you specify the following analysis
parameters:
Analyze entire disk? yes
Starting block number: depends on drive
Ending block number: depends on drive
Loop continuously? no
Number of passes: 2
Repair defective blocks? yes
Stop after first error? no
Use random bit patterns? no
Number of blocks per transfer: 126 (0/n/nn)
Verify media after formatting? yes
Enable extended messages? no
Restore defect list? yes
Restore disk label? yes
Defaults
are shown in bold.
config
Displays the current analysis parameters.
quit
Exits the analyze
menu.
