This following example shows how to create a Solaris fdisk partition and a DOSBIG fdisk partition.
format> fdisk
The recommended default partitioning for your disk is:
a 100% "SOLARIS System" partition.
To select this, please type "y". To partition your disk
differently, type "n" and the "fdisk" program will let you
select other partitions. n
Total disk size is 2694 cylinders
Cylinder size is 765 (512 byte) blocks
Cylinders
Partition Status Type Start End Length %
THERE ARE NO PARTITIONS CURRENTLY DEFINED SELECT ONE OF THE FOLLOWING:
1. Create a partition
2. Change Active (Boot from) partition
3. Delete a partition
4. Exit (Update disk configuration and exit)
5. Cancel (Exit without updating disk configuration)
Enter Selection: 1
Indicate the type of partition you want to create
(1=SOLARIS, 2=UNIX, 3=PCIXOS, 4=Other, 8=DOSBIG)
(5=DOS12, 6=DOS16, 7=DOSEXT, 0=Exit) ?8
Indicate the percentage of the disk you want this partition
to use (or enter "c" to specify in cylinders). 20
Do you want this to become the Active partition? If so, it will be
activated each time you reset your computer or when you turn it on
again. Please type "y" or "n". n
Cylinders
1 DOS-BIG 1 538 538 20
5. Cancel (Exit without updating disk configuration)Enter
Selection: 1
(5=DOS12, 6=DOS16, 7=DOSEXT, 0=Exit) ?1
to use (or enter "c" to specify in cylinders). 80
again. Please type "y" or "n". y
Partition 2 is now the Active partition Total disk size is 2694
cylinders
Cylinders
2 Active SOLARIS 539 2693 2155 80
Enter Selection: 4
format> q
