System Administration Guide: Basic Administration
How to Stop CacheFS Logging
Use the cachefslog -h option to stop logging.
$ cachefslog -h /mount-point
The following example shows how to stop logging on /home/stuff.
$ cachefslog -h /home/stuff
not logged: /home/stuff
If you get a system response other than the one specified here, you did not successfully stop logging. Check to see if you are using the correct log file name and mount point.
