System Administration Guide: Basic Administration
Commands for Mounting and Unmounting File Systems
The following table lists the commands in the /usr/sbin directory that you use to mount and unmount file systems.
Table 39–1 Commands for Mounting and Unmounting File Systems
Command
Man Page
Description
mount
mount(1M)
Mounts file systems and remote resources.
mountall
mountall(1M)
Mounts all file systems that are specified in the /etc/vfstab file. The mountall command runs automatically when the system enters multiuser mode.
umount
mount(1M)
Unmounts file systems and remote resources.
umountall
mountall(1M)
Unmounts all file systems that are specified in the /etc/vfstab file.
The mount and mountall commands will not mount a read/write file system that has known inconsistencies. If you receive an error message from the mount or mountall command, you might need to check the file system. See Chapter 42, Checking UFS File System Consistency (Tasks) for information on how to check the file system.
The umount and umountall commands will not unmount a file system that is busy. A file system is considered busy if one of the following is true:
