System Administration Guide: Basic Administration
Example—Default inittab File
The following example shows an annotated default inittab file that is installed with the Solaris release:
1 ap::sysinit:/sbin/autopush -f /etc/iu.ap
2 ap::sysinit:/sbin/soconfig -f /etc/sock2path
3 fs::sysinit:/sbin/rcS sysinit   >/dev/msglog 2<>/dev/msglog </dev/console
4 is:3:initdefault:
5 p3:s1234:powerfail:/usr/sbin/shutdown -y -i5 -g0 >/dev/msglog 2<>/dev/...
6 sS:s:wait:/sbin/rcS              >/dev/msglog 2<>/dev/msglog </dev/console
7 s0:0:wait:/sbin/rc0              >/dev/msglog 2<>/dev/msglog </dev/console
8 s1:1:respawn:/sbin/rc1           >/dev/msglog 2<>/dev/msglog </dev/console
9 s2:23:wait:/sbin/rc2             >/dev/msglog 2<>/dev/msglog </dev/console
10 s3:3:wait:/sbin/rc3             >/dev/msglog 2<>/dev/msglog </dev/console
11 s5:5:wait:/sbin/rc5             >/dev/msglog 2<>/dev/msglog </dev/console
12 s6:6:wait:/sbin/rc6             >/dev/msglog 2<>/dev/msglog </dev/console
13 fw:0:wait:/sbin/uadmin 2 0      >/dev/msglog 2<>/dev/msglog </dev/console
14 of:5:wait:/sbin/uadmin 2 6      >/dev/msglog 2<>/dev/msglog </dev/console
15 rb:6:wait:/sbin/uadmin 2 1      >/dev/msglog 2<>/dev/msglog </dev/console
16 sc:234:respawn:/usr/lib/saf/sac -t 300
17 co:234:respawn:/usr/lib/saf/ttymon -g -h -p "`uname -n` console login: "
   -T terminal-type -d /dev/console -l console
-m ldterm,ttcompat
  1. Initializes STREAMS modules
  2. Configures socket transport providers
  3. Initializes file systems
  4. Defines default run level
  5. Describes a power fail shutdown
  6. Defines single-user level
  7. Defines run level 0
  8. Defines run level 1
  9. Defines run level 2
  10. Defines run level 3
  11. Defines run level 5
  12. Defines run level 6
  13. Defines an unused level, firmware
  14. Defines an unused level, off
  15. Defines an unused level, reboot
  16. Initializes Service Access Controller
  17. Initializes console and identifies the terminal type
