Several screens are displayed as the Solaris Device Configuration Assistant attempts to identify devices on the system.
This screen appears each time you boot the Solaris Device Configuration Assistant. The Solaris Device Configuration Assistant runs every time the system is booted, although the autoboot process bypasses the menus.
The Solaris(TM) (Intel Platform Edition) Device Configuration Assistant
scans to identify system hardware, lists identified devices, and can
boot the Solaris software from a specified device. This program must be
used to install the Solaris operating environment, add a driver,
or change the hardware on the system.
> To perform a full scan to identify all system hardware, choose Continue.
> To diagnose possible full scan failures, choose Specific Scan.
> To add new or updated device drivers, choose Add Driver.
About navigation...
- The mouse cannot be used.
- If the keyboard does not have function keys or they do not respond,
press ESC. The legend at the bottom of the screen will change to
show the ESC keys to use for navigation.
- The F2 key performs the default action.
F2_Continue F3_Specific Scan F4_Add Driver F6_Help
The Bus Enumeration screen appears briefly while the Solaris Device Configuration Assistant gathers hardware configuration data for devices that can be detected automatically.
Bus Enumeration Determining bus types and gathering hardware configuration data ... Please wait ... |
The Scanning Devices screen appears while the Solaris Device Configuration Assistant manually scans for devices that can only be detected with special drivers.
Scanning Devices The system is being scanned to identify system hardware. If the scanning stalls, press the system's reset button. When the system reboots, choose Specific Scan or Help. Scanning: Floppy disk controller ####################### | | | | | | 0 20 40 60 80 100 Please wait ... |
The Identified Devices screen displays which devices have been identified on the system. From here, you can continue to the Boot Solaris menu or perform optional device tasks, such as setting a keyboard configuration, viewing and editing devices, setting up a serial console, and saving and deleting configurations.
Identified Devices The following devices have been identified on this system. To identify devices not on this list or to modify device characteristics, such as keyboard configuration, choose Device Tasks. Platform types may be included in this list. ISA: Floppy disk controller ISA: Motherboard ISA: PnP bios: 16550-compatible serial controller ISA: PnP bios: 16550-compatible serial controller ISA: PnP bios: Mouse controller ISA: PnP bios: Parallel port ISA: System keyboard (US-English) PCI: Bus Mastering IDE controller PCI: Universal Serial Bus PCI: VGA compatible display adapter F2_Continue F3_Back F4_Device Tasks F6_Help |
