The layout of the console window is highly configurable. You can use the following features to change the console window layout:
View menu – Use the Show option in the View menu to hide or display the optional bars and panes. The other options in the View menu control the display of nodes in the view pane.
Console menu – Use the Preferences option to set the following: the initial toolbox, the orientation of panes, clicking or double-clicking for selection, text and/or icons in the tool bar, fonts, default tool loading, authentication prompts, and advanced logins.
Context Help/Console Events toggles – Use icons at the bottom of the information pane to toggle between the display of context-sensitive help and console events.
