Become superuser.
Place each physical interface into a multipathing group by typing the following command.
# ifconfig interface-name group group-name |
For example, to place hme0 and hme1 under group test, you type the following commands:
# ifconfig hme0 group test # ifconfig hme1 group test |
Configure a test address for all the physical interfaces.
For an IPv4 test address, type the following command.
This step assumes that you have already configured your physical interfaces' addresses.
# ifconfig interface-name addif ip-address <parameters> -failover deprecated up |
For example, to configure a test address on hme0 with the following configuration:
Address set to 19.16.85.21
Netmask and broadcast address set to the default value
-failover and deprecated options set
You type the following command:
# ifconfig hme0 addif 19.16.85.21 netmask + broadcast + -failover deprecated up |
You can check the configuration by typing the following:
# ifconfig hme0:1
hme0:1: flags=9000843<UP,BROADCAST,RUNNING,MULTICAST,DEPRECATED,IPv4,NOFAILOVER>
mtu 1500 index 2 inet 19.16.85.21 netmask ffffff00 broadcast 19.16.85.255
You must mark an IPv4 test address as deprecated to prevent applications from using the test address.
To configure a test address on hme1 with the following configuration:
Address set to 19.16.85.22
Type the following command:
# ifconfig hme1 addif 19.16.85.22 netmask + broadcast + -failover deprecated up |
For an IPv6 test address, type the following command.
# ifconfig interface-name inet6 -failover |
Because you have already placed the physical interfaces with IPv4 addresses into a multipathing group, physical interfaces with IPv6 addresses are also implicitly placed in the same multipathing group. You might have placed physical interfaces with IPv6 addresses into a multipathing group first. Then physical interfaces with IPv4 addresses would have been also implicitly placed in the same multipathing group.
For example, to configure hme0 with an IPv6 test address, you type the following command:
# ifconfig hme0 inet6 -failover |
hme0: flags=a000841<UP,RUNNING,MULTICAST,IPv6,NOFAILOVER> mtu 1500
index 2 inet6 fe80::a00:20ff:feb9:17fa/10
groupname test
You do not need to mark an IPv6 test address as deprecated to prevent applications from using the test address.
For the second interface, hme1, type the following command:
# ifconfig hme1 inet6 -failover |
(Do this step only if you want to preserve the configuration across reboots.) To preserve the configuration across reboots, do the following substeps.
For IPv4, edit the /etc/hostname.interface file and add the following line.
interface-address <parameters> group group-name up \ addif logical-interface -failover deprecated <parameters> up |
This test IP address is configured only on the next reboot. If you want the configuration to be invoked in the current session, do steps 1, 2, and 3.
For example, to create a group test with the following configuration for hme0:
Physical interface hme0 with address 19.16.85.19
A logical interface address of 19.16.85.21
With deprecated and -failover set
Sets the netmask and broadcast address to the default value
You add the following line to the /etc/hostname.hme0 file:
19.16.85.19 netmask + broadcast + group test up \ addif 19.16.85.21 deprecated -failover netmask + broadcast + up |
Similarly, to place hme1 under the same group test and configure a test address, type the following command:
19.16.85.20 netmask + broadcast + group test up \ addif 19.16.85.22 deprecated -failover netmask + broadcast + up |
For IPv6, edit the /etc/hostname6.interface file and add the following line.
-failover group group-name up |
For example, to create a test group for hme0 with an IPv6 address, add the following line to the /etc/hostname6.hme0 file:
-failover group test up |
Similarly, to place hme1 under the same group test and configure a test address, add the following line to the /etc/hostname6.hme1 file:
To add more interfaces to the multipathing group, repeat steps 1 through 3. New interfaces can be added to an existing group on a live system. However, changes are lost across reboots.
