System Administration Guide: IP Services
DHCP Manager
DHCP Manager is a graphical interface you can use to perform administration tasks on the DHCP service.
The DHCP Manager Window
The DHCP Manager window's appearance differs, depending on whether the server on which it is running was configured as a DHCP server or a BOOTP relay agent.
When the server is configured as a DHCP server, DHCP Manager uses a tab-based window, in which you select a tab for the type of information you want to work with. DHCP Manager features the following tabs:
The following figure shows the DHCP Manager window as it appears when you start it on a DHCP server.
Figure 10–1 DHCP Manager on a DHCP Server System
Shows Addresses tab with network numbers, client names, and lease information.
When the server is configured as a BOOTP relay agent, the DHCP Manager window does not show these tabs because the BOOTP relay agent does not need any of this information. You can only modify the BOOTP relay agent's properties and stop/start the DHCP daemon with DHCP Manager. The following figure shows the DHCP Manager window as it appears when you start it on a system configured as a BOOTP relay agent.
Figure 10–2 DHCP Manager on a BOOTP Relay Agent System
The window displays the BOOTP Relay tab, which tells you to manage the relay service through the Service menu.
DHCP Manager Menus
DHCP Manager menus include:
When DHCP Manager runs on a BOOTP relay agent, the Edit and View menus are disabled.
All DHCP service management activities are accomplished through the Edit and Service menus. You use the commands in the Edit menu to create, delete, and modify networks, addresses, macros, and options, depending on which tab is selected. When the Addresses tab is selected, the Edit menu also lists wizards, which are sets of dialogs that make it easy to create networks and multiple IP addresses. The Service menu lists commands that enable you to manage the DHCP daemon. You can start/stop, enable/disable, modify the server configuration, and unconfigure the server. The Service menu also lists commands that enable you to convert the data store and export and import data on the server.
Starting and Stopping DHCP Manager
You must run DHCP Manager on a DHCP server system as superuser, but you can display it remotely on another UNIX system using the X Window remote display feature.
How to Start and Stop DHCP Manager
  1. (Optional) Become superuser on the DHCP server system.
  2. If you are logged in to the DHCP server system remotely, you can display DHCP Manager on your local system as follows.
    1. Type the following on the local system:
      # xhost +server-name
    2. Type the following on the remote DHCP server system:
      # DISPLAY=local-hostname;export DISPLAY
  3. Type the following command:
    # /usr/sadm/admin/bin/dhcpmgr &
    The DHCP Manager window opens, displaying the Addresses tab if the server is configured as a DHCP server, or no tabs if the server is configured as a BOOTP relay agent.
  4. To stop the DHCP Manager, choose Exit from the File menu.
    The DHCP Manager window closes.
