If you are logged in to the DHCP server system remotely, you can display DHCP Manager on your local system as follows.
Type the following command:
# /usr/sadm/admin/bin/dhcpmgr & |
The DHCP Manager window opens, displaying the Addresses tab if the server is configured as a DHCP server, or no tabs if the server is configured as a BOOTP relay agent.
To stop the DHCP Manager, choose Exit from the File menu.
