The following listing shows the sections, labels, and values that are contained in the mipagent.conf.fa-sample file. Configuration File Sections and Labels describes the syntax, sections, labels, and values. The mipagent.conf.fa-sample file shows a configuration that provides only foreign agent functionality. This sample file does not contain a Pool section, because pools are used only by a home agent. Otherwise, this file is the same as the mipagent.conf-sample file.
[General]
Version = 1.0 # version number for the configuration file. (required)
[Advertisements hme0]
HomeAgent = no
ForeignAgent = yes
PrefixFlags = yes
AdvertiseOnBcast = yes
RegLifetime = 200
AdvLifetime = 200
AdvFrequency = 5
ReverseTunnel = yes
ReverseTunnelRequired = no
[GlobalSecurityParameters]
MaxClockSkew = 300
HA-FAauth = yes
MN-FAauth = yes
Challenge = no
KeyDistribution = files
[SPI 257]
ReplayMethod = none
Key = 11111111111111111111111111111111
[SPI 258]
ReplayMethod = none
Key = 15111111111111111111111111111111
[Address 10.1.1.1]
Type = node
SPI = 258
[Address 10.68.30.36]
Type = agent
SPI = 257
Type = agent
SPI = 257
IPsecRequest = apply {auth_algs md5 sa shared}
IPsecReply = permit {auth_algs md5}
IPsecTunnel = apply {encr_algs 3des sa shared}
