Mobile IP Mobility Agent Status
You can use the mipagentstat command to display a foreign agent's visitors list
and a home agent's binding table. You can also display the security
associations with an agent's mobility agent peers. To display the foreign
agent visitor list, you use the mipagentstat command's -f option. To display the home agent binding table, you use the mipagentstat command's -h option. To
display the security associations with an agent's mobility agent peers, you
use the mipagentstat command's -p option. The
following examples show typical output when using the mipagentstat command with these options.
Example 25–1 Foreign Agent Visitor List
Mobile Node Home Agent Time (s) Time (s) Flags
Granted Remaining
foobar.xyz.com ha1.xyz.com 600 125 .....T.
10.1.5.23 10.1.5.1 1000 10 .....T.
Example 25–2 Home Agent Binding Table
Granted Remaining
foobar.xyz.com fa1.tuv.com 600 125 .....T.
10.1.5.23 123.2.5.12 1000 10 .....T.
Example 25–3 Mobility Agent Peer Security Association Table
Foreign ..... Security Association(s).....
Agent Requests Replies FTunnel RTunnel
forn-agent.eng.sun.com AH AH ESP ESP
Home ..... Security Association(s) .....
home-agent.eng.sun.com AH AH ESP ESP
ha1.xyz.com AH,ESP AH AH,ESP AH,ESP
See mipagentstat(1M) command for more information about the
command's options. Displaying Mobility Agent Status provides procedures
that use the mipagentstat command.
