You can use the mipagentconfig command to configure the mobility agent. This command enables you to create or modify any parameter in the /etc/inet/mipagent.conf configuration file. Specifically, you can change any setting, and add or delete mobility clients, pools, and SPIs. The mipagentconfig command has the following syntax:
# mipagentconfig <command> <parameter> <value> |
The following table describes the commands that you can use with mipagentconfig to create or modify parameters in the /etc/inet/mipagent.conf configuration file.
Table 25–9 mipagentconfig Commands|
Command |
Description |
add |
Used to add advertisement parameters, security parameters, SPIs, and addresses to the configuration file |
change |
Used to change advertisement parameters, security parameters, SPIs, and addresses in the configuration file |
delete |
Used to delete advertisement parameters, security parameters, SPIs, and addresses from the configuration file |
get |
Used to display current settings in the configuration file |
See the mipagentconfig(1M) man page for a description of command parameters and acceptable values. Modifying the Mobile IP Configuration File provides procedures that use the mipagentconfig command.
